Emu500 in RSlinx Enterprise?
neos
May 2013
Australia
37
Hi All,
With a bit or rego fudging I have managed to get the EMU500 RSlogix 500 emulator going in RSLINX Classic. Has anyone been able to set it up in RSLINX Enterprise? I am trying to link a RSview Enteprise Project to the emulator.
Cheers 🍺
NEO
RSLinx Classic is the only thing that has a driver specifically for RSEmulate 500.
If you have an OPC activation for RSLinx Classic, you can add RSLinx Classic into the FactoryTalk View project as a data server and get data from the Emulator using the RSLinx Classic driver.
RSEmulate 500 can use a PC COM port as the Channel 0 serial port of the emulated controller, and I've used that in conjunction with another serial port and a null-modem cable to connect RSEmulate 500 to RSLinx Enterprise.
hello, i am trying AB micrologix 1500 PLC with Emulator i have Set Channel 0 to modbus Slave RTU is their any software which virtually...
4,101
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
67
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
223
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
257
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
179
