Encoder error monitor for Step 7
BNA
Sep 2003
Give
117
Hi'
I am looking for a good idea to make sure that my incremental encoders are working, perhaps with an adjustable offset.
Today I take the actual value of the running encoder, move i to a temp word, then compare it with the value from the previous scan. This partly works, I just think it is to sensible.
So does anyone of you have a good idea to monitor an encoder ?
Brian
I used step 5 in university. Right now, i am much more working on
Twin CAT.
In Twin CAT i compare with Reservor value. That might be another solution.
Gents, I'm trying get some SEW Movigear motors in control by a Beckhoff PLC which is TwinCAT 3. The SEW motor is connected by EtherCAT and is...
1,314
Greetings from Michigan, USA, I have a GV3000 drive that is faulting for an encoder loss, fault "EL". However, I am not using an encoder and...
1,614
I have a quadrature incremental encoder measuring the speed of a conveyor and it is hooked up as a feedback only axis on a Kinetix 6500 servo. I...
7,130
I have finished installing Allen Bradley ultra drives and motors on my machine and it is moving fine but the drives keep randomly faulting out and...
2,701
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
246
