I have a quadrature incremental encoder measuring the speed of a conveyor and it is hooked up as a feedback only axis on a Kinetix 6500 servo. I was looking at the feedbackaxis.actualvelocity parameter and the error is a repeatable pattern starting out small, gradually increases, and then abruptly back to small again. The encoder cable length is about 40 meters. I've replaced the encoder with no luck. I've check grounding and the cable is in a low voltage wire tray. Can this be noise? Any idea?
