Encoder Monitoring via wireless
ds7891
Sep 2016
Las Vegas
77
I have an application where a customer wants to measure the position of the spreader on a gantry crane for tracking/logging. The spreader being the part that is raised/lowered to snatch the object needing to be raised/lower.
For all intensive purposes, lets say the only way to measure the distance the spreader has been lowered/raised, is to attach an ENCODER on the cable drum.
Also, this crane is mounted on rails for it to shuttle itself up/down the factory floor transporting the load.
The encoder will need to be monitored by a PLC. One theory was to connect the ethernet encoder to a wireless Bluetooth Bridge like a Wago or Anybus, and bridge it back to the network where the PLC doing the tracking resides.
Has anyone ever done this, or have any suggestions? Is this even feasible over a Bluetooth bridge....or, even a WIFI bridge?
I am not looking for a huge update rate nor do any type of control from the encoder. Again, this is strictly for tracking/logging of the spreader.
FYI - The crane control system I am not allowed to access. The encoder and bridge would be a separate system attached to the crane.
Googled “Wireless Encoder”
http://www.beisensors.com/wireless-encoders-swiftcomm.html
May be too much for what you’re wanting to do.
Keep it somewhat simple.
Does it HAVE to be an encoder? Plenty of laser measuring sensors out there with analog output. Unless there is heat or steam in the lasers path, it should work fine. Balluf makes a good one and SICK does too. Banner was hit and miss.
Just about anyone does analog in some flavor of wireless. Cheaper I’m sure too.
I've seen leaky coax solutions used for gantries/cranes before. Essentially, there is a long coax cable used, laid along one of the troughs, with slits cut in it at a regular pattern to allow wifi frequencies to escape, with a small antenna that runs along it tied to the gantry. I've used it paired with Siemens access points for profinet control, even profisafe safety IO. I've seen update rates as low as 32ms.
It isn't cheap, though, and as you said you don't need a fast update rate for logging.
Hello... Can You someone explain to me how inverter/servo encoder wire break monitoring works for A/B incremental encoders..? (in motion I can...
1,379
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
254
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
340
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,057
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
219
