Hello everyone!
Firstly I'd like to say that I'm new to this forum and also new to PLC programming world altogether, that said I really would appreciate your thoughts and hopefully some recommendations as to how to solve the problem I'm struggling with.
What am I trying to achieve?
The goal is to measure the length of an extruded plastic board using encoder with a measuring wheel. Secondary (ofcourse only if the first goal is achieved) - cut the product to length using the data from the encoder.
What have I done?
I've mounted the encoder DBV50E-22EKA2000 to the production line. I've programmed s7-1200 PLC to count the pulses from the encoder and transform the result to length measurement (millimeters). When the board is cut (by existing machinery, using a limit switch to set the board's length) the length is registered and saved to a database.
The problem I've run into.
The measurements of a given product deviates about +/- 5mm. I've attached a graph to show this deviation. In the graph you can see that large amount of boards are within +/- 0.5mm error, but occasionally some are measured with larger error to one or other side of the actual length.
I would like to hear your opinions as to what could cause such results and I would be happy to answer any additional questions about the application I'm trying to solve.
What have I done?
