OK, I am certainly not paying attention. What senses the beginning and the end of the product that you are measuring.
Sorry, maybe I have not been clear from the start.
There is already working production line which extrudes plastic board.
The board length to be cut is set by a limit switch. When the board reaches the limit switch, a signal is sent to both - the saw and to my plc to register the board length.
The board is being cut by pneumatic 'flying saw' - so a little about the saw, basically when receiving signal 'to cut' (from the limit switch) it pneumatically 'attaches' to the board by clamping itself to the board, then it moves forward with the force of the board being extruded and cuts the board with the circular saw. after cutting it releases itself from the board and get pushed back to the start position by pneumatic cylinder.
So to reply to the actual question - there is no physical beginning and end of the product at the point where the measuring wheel is rotating. The actual board length is determined by measuring distance between the 'cut' signals from the limit switch.
