Entering Product batch # in recipe
kirk
Jul 2003
Houston
71
I have an application where I want to log a batch # (input by customer) with a recipe. How would you go about handling this?
The PLC is a Allen Bradley Micrologix 1100 PLC conected to a terminal running RSView 32.
Any help is greatly appreciated.
I think a very important question is "what do you need to do with the batch number?". The answer to this question will drive what Programs and hardware you may need to accomplish your goal.
Do you just need to display on the screen?
Do you need to print out a report with the batch number?
Do you need to log batch info to a database?
Do you need to send an emal to the production manager at the end of a batch?
You have to let everyone know what you need to do with the batch number and how it will be used before anyone can answer your question.
My first inclination was to use the DATA LOGGING function in the instruction tree, but after looking at it I don't think that is an option for the Micrologix 1100.
(the way I read it is it just works on the Micrologix 1500)
I have it as a line in a spec requiring the input of a batch #. It is my understanding the scada system is going to read it. I am currently just going to put it in a Integer file, and the next entry will over write it, and if the plant system doesn't log it, it will be lost, but I think it is kind of a lame way to handle it.
Hello, the PLC in question is 1769-L30ER. I have a local 4-20mA Analog Output module (1769-OF4CI), and also a remote ethernet PointIO analog...
402
I've done this successfully using Siemens S7 1200 PLC & HMI .. it was way too complicated and expensive. Simply: Enter a numeric number (base...
2,811
FactoryTalk View-When entering a password I get "test$00" instead of "test" ? Good Afternoon, I'm working on a HMI project with...
4,241
I'm looking to find if there is a way to let a user type in long (80+ characters) worth of text using a Graphite series HMI that I can then...
2,068
Hello, I have a Schmersal safety saensor I am looking to put into the Siemens SET tool, however I only have a PFH value, Mission Time and PFD...
1,333
