Eplan p8. How do I insert a simple mounting rail?
EStufC
May 2019
Kikuara
69
Hello everyone.
Currently I am using Eplan p8 and faced (while creating a panel) with a challenge in finding a device called DIN mounting rail (usually it's 35 mm standard).
Basically could someone share with knowlewdge how to insert a mounting rail?
Perhaps someone has a macros for that.
ePLan does support DWG and DXF. Are you doing this in ProPanel?
I'm doing this in Eplan p8 as it was said at #1.
  • marking page as "panel layout"
  • insert ->box/connection/point/mounting panel -> mounting panel
  • inserting desired devices
Everything is alright (relays, modules, contactors, etc.) except mounting rails. I can't find their macroses by rittal, phoenix contact, siemens, etc.
So I am asking for help here. Perhaps someone knows a trick how to insert a mounting rail in panel.
ePLan P8 is a platform. Saying you are doing it in P8 is like saying "I am having trouble inserting text in the Microsoft package..." .... Word? Excel? Notepad?
FYI, ProPanel is an ePlan module specifically for designing the CAD of panels.
DIN Rail is not in the library, at my guess because it is a mechanical component.
I drew my own using the drawing tools.
You can download the DXF as advised and do as per attachment 2.
Macros are really for schematics and they contain connection points.
I use Eplan P8 all the time and I find it easiest to use DXF or DWG components for layouts. It is easy to build up a library of parts to use. I presume you want to do something like this below?
  • I'm using the pure Eplan p8, not ising any additional modules or utilities as Pro Panel etc.
  • The way I got a panel I had described at #5.
  • Seems the best way is a drawing a scetch of a mounting rail by means of presented graphic tools (as you also said above).
  • .dwg and .dfx are not capable with a panel because they are not macroses.
so, where your rails are? I don't see them on your panel.
My page shows a graphic (I) page.
I don't use ePlan for this anymore. My image above was an old project.
I use ePlan for the electrical schematics and a 3D CAD package for mechanical design.
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Good morning colleagues, Does anyone know the cost of an EPLAN license and where I can buy it from an official distributor?
192
Hi, I searched in forum but haven't found anything similar.. I am looking for Eplan .edz files/macros. I don't have access to data portal so maybe...
1,948
Hi All I am new to Eplan and I inherited a project that was designed in Eplan and needs rework. I was informed that the Eplan project was on the...
4,195
We have an OEM that uses EPLAN, we are an AutoCAD end user. They can export to DWG, but the images do not get exported. Do any EPLAN users have...
1,662
