EQ tank temperature & level sensor recommendation
RonJohn
Jul 2013
NE Ohio
535
I was wondering if any of you folks with waste water experience could help me out. We are adding an Equalization tank at our plant's WWTP. The tank is made of concrete, is about 30' tall and sits mostly below ground.
We need to measure level and temperature inside the tank. Access to these devices will be through a 4' square hatch on top of the tank. Temperature inside the tank will be maintained between 90 - 110Ā°F.
We'd prefer not to install an RTD 30' below grade as I'm sure troubleshooting & replacing would be a huge ordeal. We've used ultrasonic level sensors elsewhere but I wasn't sure if they are the best type for this application. If anybody's worked with EQ tank controls before, could you clue me in as to what type of devices can be used here?
Thanks in advance & Happy New Year!!!
I've had success with ultrasonic level transmitters. I usually prefer using submersible pressure transmitters, as they are less expensive and more robust. I've had luck with this type: http://www.keller-druck.com/home_e/paprod_e/36xky_e.asp
There are submersible temp transmitters like this: http://www.astsensors.com/submersible_level_sensors/AST45PT
I'mnot sure why you don't want to put an RTD below grade - use a thermowell, of course, but I don't see an issue, or a better alternate for that matter.
Does the tank have top access? If so, drop the RTD down on a cable. Easy to access, remove/replace.
Here's a sample of one vendor that has a watertight assembly (the transition to the lead wire needs to be watertight.
The issue is that the tank is already in the ground and there's no easy access to the bottom from outside. Just so happened I was in a meeting today and someone asked how we could do this. šŸ™ƒ
I'm up to my armpits in alligators presently, so I'll check out the links next year. :D Thanks again.
+1 on the AST sensors. They work well!!
AST does make an integrated temperature and pressure sensor, but I don't know if they make that as a submersible version. It might be worth a phone call to them.
I'd say go with the hydrostatic level sensor option as Tom suggested. Super easy for setting up your min and max % full readings... Just lower into into the tank until it hits the bottom then mark the cable at 100%. Pull out and measure distance from sensor to the mark. Very useful if it's an existing tank and you're not sure on accurate dimensions.
If the tank is fully sealed and you are somewhere with high humidity then ultrasonics can suffer from condensate build up on the sensor face.
If the tank is turbulent then you may need to install a stilling well to stabilize your reading and prevent damage to the sensor. A length of 2" or 4" PVC pipe with a 45 deg cut end and holes drilled along it's length works well. I only add the holes for equalization if there's a chance of sludge build up on the tank floor.
Thanks Saffa, we were concerned this would be the case.
GREAT IDEA!!
I called and the AST45PT is submersible. I think we're going to try this one out.
Thanks again!!!
hello, I am looking for a type of indicators that can measure pressure of tank , the tank contains slurry . and a temperature indicator too. I...
2,416
i have a boiler oil feed tank that i am heating it with steam manually i want to now control it now with heating element and a temperature...
1,735
Hi guys, these days, I was trying to get water tank temperature model which is used in genetic algorithm to tune PID parameter. The heater in the...
1,880
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
647
