Error 1402 while installing rslinx classic
antonydias
Dec 2007
Jeddah
Hello
I am trying to install RS LINX Classic 2.57 in my Laptop (with Windows Microsoft XP" Professional 2002, Service pack 3)
While installation i am getting an error as below
ERROR 1402 Could not open Key
HKEY_LOCAL_MACHINE\SOFTWARE\WinDNet32\Drivers.
Verify that you have sufficientaccess to that key or contact support personal
PICTURE ATTACHED
Click on Start-->Run.
Type in Regedt32 and press Enter.
This will open Registry Editor.
Drill down to the following
For 32-bit HKEY_LOCAL_MACHINE-->Software-->WinDeviceNet32-->Driver
For 64-bit HKEY_LOCAL_MACHINE-->Software-->Wow6532Node-->WinDeviceNet32-->Driver
Select the Driver folder:
For Windows 7 - Right click Driver -->Permissions
For Windows XP Pro - Click on Edit menu-->Permissions
For Windows 2000 - Click on Security-->Permissions
This will open the Permissions for Drivers window
Click Add and enter the object name Everyone Group with Full and Read control ticked for Allow.
Check the same thing for WinDeviceNet32 folder.
Reboot PC and Start installation again.
Hi there, I'm new to plc programming and was wondering why I get this error code when I run my simulation for these temperature sensors? What I'm...
48
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
347
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
184
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
143
