Error Communication MP177
SIMATIC08
Dec 2010
Casablanca
Hello everybody
I come to you after i tried to communicate with my panel a thousands time with many differents way (Ethernet, PPI/RS232, MPI , USB ... and PRAYERSSSSS :D)
I have a MultiPanel MP177 OEM 6" TOUCH (6AV6642 7EA10-0GG0) (Image V1.0.2.2_01.31 WINDOWS CE 5.0)
I used WINCCFLEXIBLE 2008 SP2 (Upd2/3/10/12/13) and SP3 too (Prosave 7.4.4 & Prosave 9)
And i could't communicate or transfert anything to my MP177
N.B : other way i used WINCC PROFESSTIONEL V11.0 SP2 (TIA) and i communicated with my MP177 but i couldn't transfert project
the message that i get each time i want to transfert is (Download can not be performed. the created configuration is intended for a different device than that currently connected) !!!!!!!!!!!!
Thank you very much
You have set the IP address on the MP177 ?
And you can ping the MP177 from your PC ?
And on the panel, the enethernet port is enabled for transfer of the project ?
You havent by chance selected a "Mobile" Panel, in sted of a "Multi" Panel when you setup the project the first time ?
The message that appears, does it possibly say that the firmware version is different, rather than the device type ?
Dear Jesper
Thank you for your interesting
I already set up the IP Adresses in my Multi Panel MP177 and My PC, and the ping was positive :)
I enabled ETHERNET Transfert, and i selected Multi Panel MP177
the reference that I have is (6AV6642 7EA10-0GG0 that i couldn't find it on siemens store !!!!! o_O)
Best regards (y)
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
132
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
387
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
132
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
758
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
720
