Error connecting via TIA V16 to HMI
hwbradshaw
Jan 2015
Dublin
I am trying to backup a program on a Windows 10 IPC running an application written in TIA v16 and download an update. The system has a Siemens 1500 PLC. I can go online with the PLC no issue. However the IPC\HMI I can not. I have checked the usual suspects in the usual way IP, Subnet. PG settings. Unless I am missing a check?.
I can see the IPC when browsing the network its PC name, IP address but that's it. Cant backup, download etc. When I try to going online the interface screen has an error
"an access node is not available for an online connection. possible reasons include a missing authorization or a faulty interface assignment in the device configuration" image attached.
The only thing you can do if you don't have the original up-to-date project is copy the folder containing the Runtime Files. Search the hard disk for *.ap16 or *.zap16 to see if there's a project on the same computer.
Is this WinCC Advanced or WinCC Professional?
If WinCC Professional, there is a utility called WinCC Start RT (or something like that) which points to the WinCC Pro RT folder to run.
If WinCC Advanced, search the hard drive for *.fwc - this is the file extension of the main WinCC Advanced RT, and copy all the files from the directory where it's located.
Hi guys anyone had this before? Latest AX5103-xxxx-0011 xml files from Beckhoff's site added in the device repository using ABB's Automation...
3,135
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
416
Hi there, I am doing a site survey for an older plant which my company has started working with. There are mutliple different PLC's around the...
4,461
Hello PLC expert i need your help. i want to use OPC communication and Matlab to read and write data from/to a Logix5561. A Topic is...
1,652
I am trying to connect the bar-code reader intermec sr61 with the micrologix 1100 but, the channel 0 indication is not blinking where the bar-code...
1,171
