Error retrieving OPC-UA server details
B&R_user
Sep 2017
Belgium
On the project i'm working on i'd like to connect Labview to an OPC-UA server on a B&R X20CP3586.
After the configuration of the B&R, i couldn't find the server with Labiew (with "Quick OPC client", part of the DSC Labview 2013 module).
So i tried to connect and gather more information on the server with the software Makitron OPC-UA Tunneller.
The Makitron software recognize de OPC-UA server, but i cannot connect to it.
OpcUa_BadTcpInternalError 0x80820000 An internal error has occurred.
What could have caused this internal error?
The server configuration on the B&R seems pretty simple, so i don't get what i did wrong.
Thanks.
Ps: for the moment my firewall is off and the DCOM parameters of the computers are correctly configured
fTff8k
image: https://ibb.co/fTff8k
update
>Modbus on TCP/IP communication is more simple to achieve if you want to communicate between Labview and a PLC.
http://www.ni.com/tutorial/13911/en/
>I'm still trying the OPC-UA server solution thought.
I cannot connect to the B&R OPC UA server.
Using the OPC UA VIEWER from CommServer I can find the server (with the IP adress):
opc.tcp://br-automation:4840/ - [SignAndEncrypt:Basic128Rsa15:Binary]
Then i try to connect to it with:
- no security mode
- no security policy
- anonymous identity
- default message encoding.
(The B&R OPC UA server is rightly configured to accept thoses modes)
Even before connecting to it i got the message:
Configuration options may not be correct because the server is not available.
Then after trying to connect:
The requested name is valid, but no data of the requested type was found
at System.Net.Dns.GetAddrInfo(String name)
at System.Net.Dns.InternalGetHostByName(String hostName, Boolean includeIPv6)
at System.Net.Dns.GetHostAddresses(String hostNameOrAddress)
at Opc.Ua.Bindings.TcpMessageSocket.BeginConnect(Uri endpointUrl, AsyncCallback callback, Object state)
at Opc.Ua.Bindings.TcpClientChannel.BeginConnect(Uri url, Int32 timeout, AsyncCallback callback, Object state)
at Opc.Ua.Bindings.TcpClientChannel.BeginSendRequest(IServiceRequest request, Int32 timeout, AsyncCallback callback, Object state)
at Opc.Ua.Bindings.TcpTransportChannel.BeginSendRequest(IServiceRequest request, AsyncCallback callback, Object callbackData)
at Opc.Ua.Bindings.TcpTransportChannel.SendRequest(IServiceRequest request)
at Opc.Ua.SessionClient.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double requestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& revisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
at Opc.Ua.Client.Session.Open(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales)
at CAS.OPC.UA.Viewer.Controls.SessionOpenDlg.Open(Object state)
Any idea?
My bad,
I made some mistakes in the B&R configuration. I mixed up OPC and OPC-UA (two differents configurations!)
It's actually pretty straightforward if you do not mix them up.
Pay attention to the certificates too, mine was obsolete.
I tested three differents OPC-UA Client tools. UaExpert is by far the most useful. You can do anything you want, the Help is OK, and the interface is easy to understand.
PS: If anyone want to use a B&R plc as an OPC-UA server:
the ONLY thing you need is a OpcUaMap.uad file in the connectivity folder of the configuration tree.
hi guys, I have been trying to retrieve the conroller time using a GSV instruction.I have defined the type of the destination tag DINT[7].When I...
2,195
Hi there, I'm new to plc programming and was wondering why I get this error code when I run my simulation for these temperature sensors? What I'm...
82
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
371
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
105
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
192
