error when opening application at rsview32
shkoko2000
May 2011
cairo
296
when i opened an application at rsview32 pop up message will apear as per attached at the picture...what can i do to solve this error...
Give the info below a try just in case cache files are in conflict with your project.
A repair I do if any issue crops up, is to shut down the project, then in Windows Explorer, go into the project folder, open the cache folder, and blow away all files in that cache folder, they will be rebuilt on the next start up.
The next thing I do is go to the projects Tag folder, and look for one file with "the project name".cac
I THEN BLOW THAT ONE ONLY AWAY, leaving all the other files in that folder, this .cac file also will be rebuilt on project start up.
Then shut down computer and reboot and run your project.
I cant promise this will fix your problem, but it wont harm it either.
The Harmony files for RSLinx they are also cache files that get rebuilt on start up.
If you havebeen doing alterations
Its also possible that the you have a corrupted tag data base and will need to export the tag data base and re import them but in my case that was at software version change many years ago
I searched for this problem on some threads , but they were dated in 2013 . When opening a program , and not all my programs , I get the following...
21,959
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
422
Respected Members; I installed Studio 5000 version 30 and RSLOGIX version 13 to 20 on my machine. I restore my computer system image two days...
1,326
I am continuously receiving an "invalid pointer" error when attempting to open any project file in Studio 5000. This is without being online with...
3,636
Hi all, I am getting Fatal error while opening Rslogix5000 Software V20.01 and software work properly with V19 & V18 . give some suggestion to...
24
37,294
