Rslogix 5000 fatal error opening any project
patrickmoneyy
Jan 2023
TN
25
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice.
I have V19.01, v20.05, V21, V24, V30, V31, V32,
&V33
All versions produce a fatal error when opening a project, or creating a new project.
V19&20 produce a EXCEPTION_ACCESS_VIOLATION
V21 and up produce
Invalid Pointer
I've reinstalled factory talk services platform
I've tried running as administrator
I've held shift and Ctrl while launching to clear app data
I've tried running in windows 7 compatibility mode
I verified I have .NET 4.5.2 and not 4.6
I reinstalled V19&20 before I realized all of them were affected.
I've deleted my harmony files
I saw one post that recommended opening a .l5k file and converting it back to a .ACD so I did that.
I'm not entirely sure what could have been changed in this time as this is a shared computer used for test benches, so anything is possible.
It was working on this PC the last time I used it in early January.
I created test projects in all versions and got the error as soon as they finished creating.
I have rslogix 5000 Pro activations in my activation manager. I haven't looked at them before but I assume they haven't changed since it last worked.
RA KB suggests downloading/installing one of the multi-versions. You probably need the extended version...
ID: IN10595 | Access Levels: Everyone
Studio 5000 Multi Version Installation Package​
rockwellautomation.custhelp.com/app/answers/answer_view/a_id/1089691
Contacted Rockwell and got the issue resolved. Someone had updated activation manager to V5.01.
If Factorytalk services platform is lower than V6.30, installing Activation Manager V5.01 will cause the fatal errors I described.
Updated my services platform and all versions of L5K are working again.
I've googled and searched for this error but can't see it anywhere. When I try to open this program I get the following. Error 0x8004201d...
3,983
Hello All, I have been getting this fatal error repeatedly when trying to connect to a PLC in our facility. I have never come across this...
1,827
Help! I have been using RSLogix 5000 on my laptop for over a year now (Version 20.01.00), and have recently installed RSLogix 500 on the same...
8,808
I have problem while I try to download RSLogix 5000 Program file to PLC. It appears Fatal Error ! as picture attached. When i click OK button...
12,791
Hello, a while ago I installed rslogix 5000 in my computer, but didn't used it. Now that I want to, it shows some fatal errors. Does anyone knows...
4,334
