RSLogix 5000 Download Fatal Error !
alpine
Dec 2011
Bangkok
51
I have problem while I try to download RSLogix 5000 Program file to PLC.
It appears Fatal Error ! as picture attached.
When i click OK button, RSLogix 5000 Program will exit !
Anyone can suggest me to fix this problem please, because
while I can not download any RSLogix 5000 program file to PLC
At first glance I thought maybe you have a RSL5000 version issue. I'm not sure but that error may be coming from windows. Are you using XP by any chance?
Do any of your other programs work? By this I mean
A. will ALL other programs on your computer work properly? and
B. Can you download a blank project to the controller with the same method?
Answer to Mr.PLC Pie Guy
To Mr.PLC Pie Guy
I use RSLogix 5000 V13 and use Windows 7 (32-bit)
This problem occurs after I uninstall RSLinx V2.58 from my computer
and install RSLinx V3.60
A. The other programs work properly including other rockwell softwares
such as RSLinx and FactoryTalkView Studio.
B. I can not download a blank project to controller because
when I click "Who Active" button on RSLogix 5000 program
the dialog box "Fatal Error !" (as shown in picture attached)
will appear.
You need to read the Release Notes that come with RSLinx and make sure it's compatible with RSLogic V13. It may not be.
Another approach is uninstall RSLinx and install the older version.
Rockwell is notorious for version compatibility problems.
Official Support
Windows 7 (64-bit)
  • RSLogix 5000 v19.00 and greater
  • RSLogix 500 v8.40.00
  • RSLinx Classic v2.57or greater
Windows 7 (32-bit)
  • RSLogix 500 v8.30.01
Windows Vista (32-bit)
  • RSLogix 5000 v17.00 and greater
  • RSLogix 500 v8.00 or greater
  • RSLogix 5 v7.40
  • RSLinx Classic v2.54 or greater
Exceptions
RSLogix 5000
RSLogix 5000 software v13 through v18 are now known to operate correctly on Windows 7, if using suggested configuration settings.
http://plcview.blogspot.co.uk/2012/02/rslogix-55005000-on-windows-vista-and.html
Thank to Mr. GTUnit and Mr. the_msp
I will read in RSLinx Release Note and blogspot to find that
RSLinx V3.60 is compatible with RSLogix 5000 V13 or not
To Mr.PLC Pie Guy
will appear.
Had the same issue with V16. Had to reinstall V16 after an Rslinx upgrade
If you have the installation files for V13, reinstall
To Mr.curlyandshemp
To Mr.curlyandshemp
Do you mean that for RSLinx upgraded to V3.60 in my computer,
I should uninstall RSLogix 5000 V13 and reinstall it again ?
To Mr.curlyandshemp and Mr. jdbrandt
I will try to uninstall RSLogix V13 and re-install it again so that this problem
may be fixed.
Thank to Mr. GTUnit, Mr. the_msp and Everyone
Thank to Mr. GTUnit, Mr. the_msp and everyone
I uninstall RSLinx V 3.60 from my computer and re-install RSLinx V2.57,
then I test by download & Upload RSLogix 5000 V13 Programming to/from
CPU, It works properly.
Thank to Everyone.
alpine
It had happened twice to me with version 20 of rslogix 5k on windows 7 32 bits, version V19 of same program running on same computer works fine with no problem. I had to uninstalled and installed v20 twice.
Studio 5000 fatal error
Hi Everyone.
I have ran into a similar problem as discussed above.
But my problem is coming when i am downloading into the PLC.
I am able to download blank project.
I have Addon Instruction in my program. So, whenever i download with AOI called in Main routine Fatal Error is coming.
Note: I am using Studio Logix 5000 v31, RSLinx Classic v4.00
I will be thankful if i can get a solution for it.
Thank you.
Hi Everyone.
Thank you.
Same issue here.
Did you find any solution?
Thanks in advance
Hello Gentlemen, I am having this weird issue. I can see the controller on Rslinx via ethernet. when I open the RSlogx 5k, open RSWho, I still...
1,989
I have a pc running windows 10 pro that is on a network that does not have internet access. I need to put RSLogix 5000 on this computer for a...
4,747
I'm getting ready to make some changes to a legacy centrifuge machine with an L61 CPU and version 17 firmware. I need update one of the the PF700...
1,781
I cannot find the install disc for rslogix 5000 V20. I have an activation for studio 5000 which also allows to run rslogix 5000, however I can't...
29,580
Hey guys, It may be a beaten dead horse, but does anyone have any recent information as to whether or not a legit link may exist for the free...
42,563
