Rslogix 5000 Upload, download, Go online, update firmware all grayed out
bdauliya
Supporting Member
Sep 2020
New York
34
Hello Gentlemen,
I am having this weird issue. I can see the controller on Rslinx via ethernet. when I open the RSlogx 5k, open RSWho, I still see the controller but the option to go Online, Download and Upload is Grayed out.
I have a valid license for RSlogix 5000. I did try removing harmony files and re installing the whole Rockwell package. the issue seems to be persistent.
Have anybody faced this and solved before ? please suggest. TIA!
try finding the PLC using factorytalk linx
also when you open the controller in studio 5000 and go into to try to upload up top there is a drop down menu to select if you are using factorytalk or rslinx to find the PLC
Make sure you are selecting specifically the processor in RSWho, not eg the network card in the rack. Do not drill down past the controller.
It seems like there is data loss from ethernet cable as I plugged in to unmanaged switch.
I used USB B Cable to hook up to controller directly. I can now upload, download and go online.
I'm getting ready to make some changes to a legacy centrifuge machine with an L61 CPU and version 17 firmware. I need update one of the the PF700...
1,781
Hello All, I have been getting this fatal error repeatedly when trying to connect to a PLC in our facility. I have never come across this...
1,827
Hello, It's seems that i can't make an upload from the safety PLC. Im using a L61S PLC. I'm able to start the upload, but when its half way...
2,277
Is a save in RSLogix 5000 essentially an upload? Are all tag databases saved in either case? Are there any glaring differences between the two...
2,326
I am trying to use the upload download tool but when I hit the browse tags button on step 5 I get "Error 380 Invalid Property Value". It does not...
14,615
