Rslogix 5000 upload fault v. 18.02
drmarty
Jan 2019
holland
Hello,
It's seems that i can't make an upload from the safety PLC.
Im using a L61S PLC.
I'm able to start the upload, but when its half way trough it just stops and i get a message.
''Failed to upload project reverting to the last saved copy"
Also tried it with a different laptop but i get the same thing
I've checked some other topics but they don't have the same issue is i do.
I dont get a fatal fault.
I have 2 others L63 PLC's but they just work fine.
I've added a screenshot
Is someone familiar with this?
Thanks ill try that tomorrow, today ive contacted Rockwell but they said that the file in the PLC might be corrupted.
If the solution in technote doesn’t work, then all is left to make a download of an old back up. Costumer won’t be happy with that��
I’ll will post the update
Hello Gentlemen, I am having this weird issue. I can see the controller on Rslinx via ethernet. when I open the RSlogx 5k, open RSWho, I still...
2,005
I'm getting ready to make some changes to a legacy centrifuge machine with an L61 CPU and version 17 firmware. I need update one of the the PF700...
1,787
Hello All, I have been getting this fatal error repeatedly when trying to connect to a PLC in our facility. I have never come across this...
1,838
Is a save in RSLogix 5000 essentially an upload? Are all tag databases saved in either case? Are there any glaring differences between the two...
2,333
I am trying to use the upload download tool but when I hit the browse tags button on step 5 I get "Error 380 Invalid Property Value". It does not...
14,626
