Error while trying to download S7-1214FC
swedeleaner
Dec 2013
Göteborg
143
Hello!
When trying to load the hardware configuration I get error 0050-133 2 2458, check the diagnostic buffer.
When checking the buffer, it says something about a memory card that is missing.
Quite sure I don´t need one.
I tried to create an empty project with just the CPU and download, but still get the same error.
I tried MRES but no luck there either.
What can I do?
Is the CPU corrupt?
Using TIA V18, CPU is firmware 4.5
How big is your project? The 1200s have some load memory integrated, but it doesn't cover larger projects. Program Info claims to show a load memory calculation, but it only shows the load memory requirements of the program, not the HW. I've seen systems where the actual load memory required was at least 2x as big as what the compiler said.
You can try a factory reset on the CPU and see if that helps.
I was going to comment something similar to this, but if you try to download a project that's too large then the error message tells you exactly that without mentioning a memory card. I also don't think that there's a way to specify in the hardware configuration if you're using one or not.
What may help is putting the CPU to stop mode when downloading. I've found that if you're nearly at the memory capacity it will refuse to download while in run mode.
Hi all, I am getting a Fatal Error of 0xc0000005(-1073741819) While installing V21.03 on Computer(please refer to the attachment ) please help
1,785
Respected Members; I installed Studio 5000 version 30 and RSLOGIX version 13 to 20 on my machine. I restore my computer system image two days...
1,323
Hello PLC expert i need your help. i want to use OPC communication and Matlab to read and write data from/to a Logix5561. A Topic is...
1,650
I am trying to Install RSLinx Classic Lite on a remote machine so I can use the Clock Sync Tool, But I keep getting this error. Error 1320.The...
8,144
Hi all, I am getting Fatal error while opening Rslogix5000 Software V20.01 and software work properly with V19 & V18 . give some suggestion to...
24
37,273
