While installing V21.03 on Computer getting Fatal Error of 0xc0000005(-1073741819)
jithinraj171
Apr 2022
bhopal
Hi all,
I am getting a Fatal Error of 0xc0000005(-1073741819) While installing V21.03 on Computer(please refer to the attachment )
please help
It says unrecognized O/S. What version of Windows are you using? Is there a reason you are using 21.03? It has some serious limitations that earlier revs of v21 do not have.
OG
If I'm not mistaken, doesn't V21 have the same issue V20 has with V20.01 and V20.03?
Yes there is a compatibility issue between minor revisions of v21 if that's what you mean. Seems unlikely to be the source of this particular problem.
I agree that this is not the issue the OP is having. I just suggested using a different revision if that is an option.
And at risk of going off topic, the concerns were specifically with 20.03 and 21.03 and their different behavior with handling minor revisions. No other versions or revisions, earlier or later were affected.
OG
Ran into this one a few times.
Try running the application directly from the source folder in administrator mode.
Should be able to be selected here:
C:\Program Files (x86)\Rockwell Software\Studio 5000\Logix Designer\ENU\v21\Bin\LogixDesigner.Exe
Right click - "Run as administrator"
You'll be good to go...
Then, like OG says, drop down to V21.00
-Mike
Hi everyone i'm trynna install Tia portal v15 The installation starts normale but it suddenly stops asking for a reboot , When i restart the...
32
8,269
Good Evening , I am getting ready to install a remote Flex I/O 1794-AENT. It is going to be difficult to shut the line down to install. I...
2,347
Hello I am trying to install RS LINX Classic 2.57 in my Laptop (with Windows Microsoft XP" Professional 2002, Service pack 3) While installation...
1,789
Hi guys, To make a short story of my problem, We had studio view 6.000 here installed on our laptop and alot of the automation have been done...
2,536
Hi, When installing the WinCC flexible upgrade from 2005 to 2008, there is always an error when installation the Microsoft SQL server software. At...
6,881
