esa wt150 and floating numbers
tny
Jun 2005
usa
105
hi,
does anyone know how to use real numbers with esa panel?
i have to show real numbers from a data block of a s7 300 plc.
i defined real numbers in a db of s7 300, a variable as dbw floating point, and a numeric field as floating point. but i can only see ******* signs at the panel. how can i solve this problem?
thanks..
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
110
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,477
Hello. I have a very old project (more than 20 years ago) made for a VT-570 I should open, mostly to understand which data are exchanged with...
690
Hiii, guys I need to take backup from esa vt series hmi like vt 310w n vt 170w . Plz tell me how to get it. Also I have vt 5.17 version and...
1,844
Hi Group My control box uses 110VAC incoming from customer supply. It has a PLC and a DC power supply both running on 110. The PLC draws 0.8...
1,706
