ESI Block in ProWORX 32
mehret
Apr 2008
Palmerton/Williamsport, PA
17
Ok, so I'm trying to get the Modicon ESI06210 ASCII module to work in ProWORKX 32. The problem I'm having is that I keep getting a 1000 error in my ESI block, which means that the length of my bottom node isn't long enough. However, I checked all the blocks in my program, and theyre all a value of #0010.
Can someone provide any insight into what else could be causing this error?
Hello all I use a few tools for editting various EDS files, but can't seem to find an EtherCAT ESI file editor. Can anyone suggest something...
1,595
Anyone have experience using Unity Pro function block MUX command words to read serial data? We are upgrading from an Allen Bradley PLC 5/40 to a...
3,195
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
135
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
143
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
138
