Estimating load inertia
aand74
Dec 2005
Deinze
131
I am doing a revamp of a machine with motion control.
I have no data of the inertia of the load on a certain motor, but I should want to know it for my engineering.
In the old drives I can capture analog output that indicates the setpoint speed, and an analog output for the current. I am not sure if I can set it at the torque generating current or if it is only possible to read the total current.
I should be able to scale the two signals so I have signals in rpm and ampere.
I also know the reduction ratios of the gearbox.
What could now be a procedure to get a value for the inertia of the load?
The old motor is a servomotor.
Apply a step speed demand and measure the time it takes to get from 20% to 80% of the speed ensuring that the torque during the accel is constant. Repeat from that speed and measure the time from 80% to 20%. Average the two values to eliminate friction and then calculate the inertia from T=I.Alpha
If you know the weight you can do a calculation. What kind of load is it? IE a rotating roll, moving on a track, etc?
Also keep in mind that the inertia reflected through a gearbox is scaled by the gear ratio squared.
I have been working for a small turn key machine builder. We mostly do table top machine which do a few automated steps in assembling a product...
20
5,342
We have a machine that is currently down and being completely rebuilt. As part of that rebuild I have a sub-project to replace virtually all the...
22
3,994
Has anyone come across any good resources for developing data flow estimates from PLC's, for some given inputs and constraints? We have a network...
4,912
Is there anybody here who is involved with estimating final price for an automation system in a tender (and not necessarilly just in a tender). I...
4,166
Expanding on interesteds topic of How much do companies charge for A programming a new file and B fault finding a customers code. what is the...
3,246
