ET200Pro F-Switch
tim2
Nov 2004
245
Anybody ever worked with an F-switch?
I'm still at the point of trying to figure out the safety system, but have to use this piece of hardware. The initial confusion is why for a module with 2DI and 3DO that the address space is several bytes for inputs and outputs.
For example, on the first rack, and F-switch is placed into slot 7. The address space is Inputs: Bytes 9 through 15, Outputs (bytes 9 through 13). Why so much space for the addressing?
I'm trying to find out what should be fairly simple things: how are the two actual inputs addressed, the three outputs, and what's taking up several bytes of I/O memory.
I have looked at the Siemens documentation and it's just not popping out at me. If anybody can lead me to a good tutorial or any training material on Siemens F systems I would truly appreciate it. Thanks.
Looking for CAD drawing for a 6SE7-194-4DCO0-0AA0. It has 8 inputs and 4 outputs. Thanks
5,695
I'm looking for the Siemens manual: 'Decentralized peripheral system ET 200pro' I couldn't find it on the support website...anyone got a copy...
2,925
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
249
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
196
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
81
