Ethernet cable range
plcsoftvsd
Sep 2007
23 15 13.2 N 77 27 28.75 e
132
I am in a a bit of fix ..we have a project wherein we are using ethernet cables to connect between 6 PLC's but the distance is 145 metres. ( and i think 100 metres is the maximum length recommemded for ethernet cable).
What could be good economical solution for this problem,
The fibre optic solution is expensive as i need to buy FO switches for all the 6 plcs i need to connect.
cheers.
Even more economical:
Just connect a 145 metres ethernet cable of good industrial quality (=Profinet). I have done that many times up to 150 metres with never a problem.
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
262
Hello Everyone, I was wondering if anyone has any suggesting on getting Ethernet Cables with RJ45 connectors into control panels. Looking for...
1,779
What is the symbol for a Ethernet cable on a Loop Diagram?
825
Hi, Dose anyone have recommendations for Ethernet cable for site-use with laptop? I usually use regular office cable, but the lock-pin usually...
3,900
Hi, expert: we have one machine with 6 Sercos axis (kinetix6000) controlled by L71, there are 1756-M08SE and 1756-EN2T and one input module and...
2,697
