Ethernet Cables
nmurray
Apr 2014
USA
90
My company custom makes their cables, and I've worked for other companies that do the same, and we have some failures in the field.
I contribute most of these failures to poor cable end construction. I have made cables before I know they can be a pain.
Do you guys run into this issue at all?
Also are their any easy make connectors that are more foolproof that still work well in industrial settings
(I've seen some but they don't look very well grounded)
This tool along with the special feed through connectors have changed my feeling about doing a task I used to hate:
http://www.platinumtools.com/products/crimpers/ez-rjpro-hd-crimp-tool-100054c/
http://www.platinumtools.com/produc...5-for-cat5e-cat6-with-internal-ground-100020/
No longer is it necessary to try to get all 8 wires the exact length and all inserted simultaneously. Just strip them back 2-3 inches, insert 1 wire at a time, then let the tool crimp and trim.
I have probably made close to 100 connectors with this tool and yet to have a single bad end.
Most of the time we are using these connectors together with Lapp ETHERLINE® Cat.6A H, had no problems whatsoever with them. All you need is a small wirecutter, maybe some pliers.
http://www.metz-connect.com/us/products/130e405032-e
We tried Harting connectors but they are a royal pita... I think none of the crimping type connectors that we tried would support the large cable diameters.
What really matters is to test each connection, not only for wiring faults but actual traffic performance. We don't have to certify the network cabling for our customers but it's nice to have a report of the results after initial installation.
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
113
Is there really any difference? I see the ethernet are typically colored teal and the profinet green. They appear to have the same pinouts - and...
6,905
If you run into the ugly problem of terminating waterproof underground-grade ethernet cable, with all that gel spewing out of it, you can spray...
1,520
What do most do out there in regards to ethernet cabling? Buy pre-made cable lengths for use in panels? Buy a spool and crimp your own? If you...
29
7,599
Hy, can we use shielded ethernet cables for drive-cliq connection to sinamics s120 components? Will any problems happen? I contacted siemens...
4,260
