Waterproof Ethernet cables
KirkC
Aug 2015
California
55
If you run into the ugly problem of terminating waterproof underground-grade ethernet cable, with all that gel spewing out of it, you can spray the stripped end with WD-40, the miracle solvent, and wipe the gel off with a towel. Squeeze the gel out of the last inch first. The push-through RJ-45 connectors work better than the normal ones for this application.
Excellent tip !
I'm curious about what kind of environment you're putting this cable into.
Is it in conduit that will potentially fill with water, or is it outdoors exposed to rain/snow, or is it directly buried in earth ?
Is there a specific reason you chose gel-flooded instead of waterproof tape ? I don't know much about either one and it would be neat to get some direct user information.
Don't know, Ken.
The water-proof ethernet cable has been a given, not something I specified. Technically, I think you're are supposed to use fiber or isolators between sites with distint grounds. That may be the problem.
You still want to elimate a goo-drended connection to be the source of the problem.
Hi all, Looking for recommendations on some ethernet cameras suitable for hygienic/washdown areas, that I can embed into an Ignition SCADA...
2,352
Waterproof Industrial 3.5mm Speaker for use with ThinClient and FTView Alarm&Events Hello, Elsewhere at this site the thinclients (Dynics BTMM)...
874
We have an area at work where the humidity and caustic water is breaking down our 18mm proxes and shocking people. We currently use: AB 871C...
3,369
Hello I am looking for a waterproof (IP65 or greater) touchscreen monitor, preferably with an HDMI input and powered by ELV, preferably 24V DC...
3,055
161
