Recommend: Waterproof Prox?
K7JLJ
Mar 2016
Oregon
21
We have an area at work where the humidity and caustic water is breaking down our 18mm proxes and shocking people.
We currently use: AB 871C 2-wire AC Plastic Barrel Tubular Sensors
Can anyone recommend a better solution that is 120vac 2 wire?
Thanks.
Thanks mendonsy,
The ABs are IP67 also, but I think you need IP69K to get the 1200 PSI rating.
The water is about 290F and I'm thinking the only option might be to switch to the food grade stainless tubes so at least if they should ground out to their case it will take a path to the platform instead of being insulated in the mount.
the ip rating is only part of the equation.
you need a nema rating - 4x - corrosive rating if I remember correctly.
next, what is the acid in the water?
then you go to AB, Omron, peperal fuchs and tell them what the application is and the caustic substance to see what stainless material you need.
is this a food industry? stainless steel 316
you select a prox switch based on the caustic material.
now for the bigger issue.
you should consider switching to 24 volt sensors if possible before someone gets seriously hurt. may not be practical to do, but you need to plan for something.
james
Normal ph is 5-6 it at the head box of a Fournier paper machine. Periodic clean outd raise the ph much higher but I do not know how much.
24vdc is not practical in this case and it's only two proxies in the area.
Look into the Allen Bradley stainless barrel 2 wire 871TM line. We use 871TM-BX21-N3 extensively with 120VAC in a food manufacturing caustic washdown environment and haven’t experienced shocking. I have seen shocking from plastic barrel proxes from at least two other manufacturers.
Edit: I just looked at the AB website. These might be discontinued next year, something about DeviceNet. I hope it's just the DN version being dropped. They’ve been excellent sensors. There’s apparently 2 wire all stainless in the 871T line we might have to try someday. Otherwise, consider also Turck. We found a higher temp rated Turck for one application but haven’t tried it. Reworking some heat shields has gotten the AB prox close enough to ratings to last.
IFM has a great line of washdown and SS proxes. Some specific for food & bev industry that are corrosion resistant.
Thanks guys for the help, I will try the AB prox @5618 suggested.
AB is the preferred manufacturer for the plant so will go that route first.
++1 on swapping to 24VDC, nasty things can happen with water and AC.
Someone really needs to come out with a line of devices that work in harmony with chemicals.
Even food grade stuff isn’t all that great. In our world, the sensors last but the cables literally melt away, same with enclosure gaskets. That occurs with only the off-gassing of the acids.
I don't suppose anyone makes a 24vdc prox to 120vac setup?
I have a JIC within 6ft that I could put some kind of base unit in to feed 120vac back to the PLC if such a "base unit" would feed 24vdc to the prox?
A drop relay is not the answer and the run can only be done on an outage with much "ringing of hands" so the policy is "don't touch 120vac proxes when you are in a shower".
Side note... for those that use proxes in the washdown areas, do you have issues with a QD connection or do they work as well as straight corded proxes?
IFM's has QDR cords made for washdown. They have an o-ring to seal, are SS, and have a built-in torque limiter so they don't get overtightened. Never had a problem with those.
A quick count in my head, we use at least 45 of these with QD. We use Allen Bradley and Brad Harrison cables. PVC jacket works fine for us but TPE might be worthwhile for some environments.
We don’t have problems with water infiltration but coupling nut material can be a problem. We grease the threads of these and just about everything. Epoxy coated zinc does very well unless the epoxy gets damaged. Stainless is fine but there’s a risk of galling if not greased. Plastic can be stripped by pliers people who know tighter is better. Brass or aluminum would corrode for us.
This might give you a reference: Washdown uses 70 psi Strahman and 600 psi wands. Alkali cleaners are applied with hand pump sprayers or foaming hoses.
Good Morning , I have worked with many robot integrators through the years ,and was looking at Pearson Packaging Systems . Have many of you used...
2,206
Hello PLCS.net! I'm about to program my first Robot soon! It's going to be a Fanuc. But wait, there's more! It's also going to be collaborative...
3,362
I need to do some simple schematics, I don't need (and would never use) 3D modelling rendering etc. For those with long memories, AutoSketch would...
20
8,496
Hello all, Is any good analyzing software. We have a bunch of data in text files. Need to analyse. Right now we are using DIadem. Is there any...
2,283
Can someone recommend me a compact device to control logic on/off beacon according to signal from a PIR ? Some RTU maybe. I am newbie in...
2,194
