Recommend me a Logic Programmable Device Compact?
asterixyz
Mar 2020
South America
Can someone recommend me a compact device to control logic on/off beacon according to signal from a PIR ?
Some RTU maybe. I am newbie in automation device.
It will be used in a truck in miner open pit.
Thx
Maybe more details would help... what are you doing with the beacon ? what is the PIR? does the PIR manufacture have anything that will interface?
Oooh sorry.
Beacon will warn when a operator/driver is inside of cabin of truck, while it is stopped. Beacon will be arround the truck in exterior of course. The PIR sensor send a voltage 24 vdc when a movemnent is detected.
I thought I can solve this using only a pair of solid state relay. However I would like to add external comunicación to connect a server or similar in the future.
Initially I found a SIMATIC RTU3010C, but it is so expensive :(
I think I would contact the truck manufacture and let them know what you are wanting to do and see if they have any options
Thanks for the details !
In this context, a "PIR" is a Pyroelectric Infrared Sensor, of the sort that are built into simple motion-sensing
and occupancy sensors of all sorts. I have one that turns on the lights in the washroom at work, and two
that light up the path and doorway when I get home at night.
Controlling an external beacon with one of those switches is a trivial task as long as the voltage and current
of the PIR sensor are compatible with the beacon. A quick Google search finds 12V to 24V compatible ones for $10 USD.
Connecting a discrete input to an RTU or radio telemetry system is a much bigger question.
Do the trucks already have telematics ? Do they use your local cellular phone networks ? Are there auxiliary inputs in those telematics systems ?
What sort of "Server" do you want to communicate the truck occupancy or other information to ?
Is there other truck information you want to send to a central server, from the engine or HVAC or fuel or payload or GPS location ?
Good Morning , I have worked with many robot integrators through the years ,and was looking at Pearson Packaging Systems . Have many of you used...
2,206
Hello PLCS.net! I'm about to program my first Robot soon! It's going to be a Fanuc. But wait, there's more! It's also going to be collaborative...
3,362
I need to do some simple schematics, I don't need (and would never use) 3D modelling rendering etc. For those with long memories, AutoSketch would...
20
8,494
Hello all, Is any good analyzing software. We have a bunch of data in text files. Need to analyse. Right now we are using DIadem. Is there any...
2,281
Hi everyone. I would like to know what are some brands you have had good experience with and what to stay away from. And do you have any...
3,045
