Ethernet Connection Between SLC 5/05 C series & PVP 1500
PLC-OCP
Apr 2012
France
Hi , I'm Trying to connect SLC 5/05 C series & PVP 1500 with Ethernet Cable But The connection is not established
SLC/IP : 169.254.115.59
PVP/IP : 169.254.115.60
MASK : 255.255.255.0
The PLC & PVP has successfully configured with a PC But when i try to connect PLC with a PVP a Enet Led is down
Thanks for Help
To make a crossover cable if you don't have one, swap green w/ orange and green/white w/ orange/white on one end.
If you don't have cable ends handy, put a network switch(even a desktop switch will work for a quick test) between them.
Did you click the "copy from design to runtime" in RSLinx Enterprise when you set up the path to the processor during the design. Do you have the "replace communications" in the transfer utility when you downloaded the project to the panel view? Doing this will over write any existing paths that are stored in the panelview. Are you running through a switch or are these the only two devices?
connection between PC, SLC and PVP
Hi, Thanks for help
But If I use Switch for connection between PC, SLC and PVP ,I should use a crossover cable.
Hello All, I was wondering if anyone had any luck with setting up ethernet/ip connection between Productivity and Datalogic Vlase laser?? Any...
1,471
Hi, Sorry if this is an existing thread this forum doesn't give me the ability to search prior to posting. Does anybody know of a way in which i...
2,437
Hi, guys, how’s going? We get one SIMOTION D435 machine. The communication between D435, PLC and HMI is built by Ethernet cable. (D435 IP...
4,918
Hi all, I am trying to load a program to a simatic panel I have set up the ethernet communication so that both my pg and my panel have the...
2,392
We have siemens s7 300 PLC which is connected with Hitachi PLC through ethernet with CP343-1. When we connect another computer in that network, we...
7,165
