Detection of Ethernet Connection Fail between PLC and HMI
DanC2188
May 2013
England
Hi, Sorry if this is an existing thread this forum doesn't give me the ability to search prior to posting.
Does anybody know of a way in which i can detect a failure between a S7-300 PLC (code written in Simatic Manager) and a Siemens HMI? (code written in TIA Portal)
I have changed cabling and it seems to have changed the faulty issue, nice and simple! BUT I was asked if there was a way of detecting if an Ethernet cable loses connection to a PLC. I didn't know if there was a bit I can pull from the status or if someone knows of a script that can be written? I have little a very small amount of experience with scripts.
If anyone can help I would be most grateful.
Thanks in advance!
There is a DeviceStates (FC802) Siemens block, but as far as I know it only works for ProfiNet or ProfiBus. I don't know of one for ethernet.
Any one have any good industrial grade vibration monitoring sensors that are Ethernet or any industrial protocol really. Just want data in without...
1,454
I am setting up a new system consisting of 3 racks, one Panelview Plus 1500, and two processors. One processor will act as the master control for...
13,482
I have a FX3U clone that I am failing to get a simple Structured Text example working on and would really appreciate some help. I created a...
30
986
I have an application where I want to use a safety relay in combination with a flame detector as the sensing element. The flame detector has relay...
23
1,088
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,081
