ethernet/ip bench scale
escoplcguy
Jun 2010
New Jersey
191
hey guys!
were looking to purchase a new bench scale and have it integrate into our plc5.
we want it to be ethernet/ip (were using a side card Series B, Revision A or later)
this is something we were looking at
http://www.arlynscales.com/ProductDetails.asp?ProductCode=BENCH-SCALE
wanted to know if anyone has had any experience with this scale with the ethernet option, or if you guys could recommend one that would fit our needs.
if you think this one will work how do i set up the MSG instruction in the plc 5? Would i use a plc-5 typed read??
Thank you!
202
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
101
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
479
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
549
