Ethernet/IP - DLR on a dual port NIC PC
You don't really need to put DLR hardware in the PC.
Just use a DLR switch such as Allen Bradley Stratix switches to handle the DLR for you and plug your PC into the switch.
Thanks, Robert... I had to dig all the way into the User Manual to find that the cifX does support Device-Level Ring.
I had to find it there too. I guess they have a switch chip on this card - not that common to see a PC card with a switch chip. Most multi-port cards are just individual Ethernet adapters bundled onto a single card.
You normally would use this when you want a workstation or PC based HMI (FT View SE anyone?) in the middle of a DLR run and you are not near the switch. This card will let you have your workstation and not break the DLR ring.
It's use the same way when just doing a linear device to device run and not using switches or DLR. I am shocked that AB has dual port panel PC's but they don't have the switch chip in them to have this capability. It's limiting and I have had to pull the existing card out of the Rockwell panel PC and change it to a DLR type and remember to change it back if the unit ever fails and they send it out for repair. Bubba and Cletus will just plug the cable into the 2 ports on the new panel pc even though they plugged into the DLR card in a different area then call that night and wonder why the line won't work.
Does anyone know of an IP67 field-mountable Ethernet switch that supports the Rockwell "Device Level Ring" protocol, but isn't a Rockwell...
1,330
Hi Guys! I'm setting up a small DLR test system at my desk, consisting of one CompactLogix PLC and one FC102 (Danfoss drive). If I use the EDS...
3,392
I've been trying to troubleshoot a DLR network for the past month with some forward progress, however I've exhausted all of the things to try that...
4,794
Hello, I have a customer with a Rockwell DLR network. I wanted to know if a regular EtherNet/IP slave/adapter device can be added to this kind...
5,564
161
