Ethernet/IP Interface Module MVI71-DFNT
CoastalControl
Mar 2005
Panama City Beach, FL
29
This module is made by Prosoft. Ethernet/IP Interface Module MVI71-DFNT
My question is, has anyone used this card for Ethernet communication from the AB PLC 5/60 to any HMI's.
I would like to string 8 HMI's on this card and would like some help.
I am replacing Hard Wired control stations with the HMI's. If this sounds like an acceptable way of doing this, please let me have your comments.
Thank you,
Pat
I don't see a problem with that. I've used a couple of the Prosoft cards, a couple of caveats though. First, I believe the maximum update rate is 1/10th of a second. Last, the data in the config file is processed sequentially so if you have some buttons that are more important than others, you should put them at the top of the list.
Jay
Hi everyone, I'm trying to find documentation on how to interface a NP1L-ET1 EtherNet module which resides on a Fuji PLC backplane. There doesn't...
1,389
How to Interface the Printer with Controllogix L62 via a AB Generic Ethernet Module Hai All, I Need to interface a Generic Printer with the...
5,678
Hi all I have here an AB PLC system including: - 1768-L43 CompactLogix PLC processor, firmware upgraded to 20,12 - 1768-ENBT Ethernet scanner...
4,369
Allen Bradley Control Logix 5561 Series Model 1756-L61 Series B Controller. Panel View Plus 1000 HMI Touch Screen. Communication Module 1756 ENBT...
4,611
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,011
