Ethernet/IP question
Tactician
Nov 2011
SK
Hello,
I am new to this forum but have been around PLC's for awhile. I am doing a design for a new flexible automation fixture and had a question. Does Ethernet/IP I/O have the same ability for plug and play as Devicenet? I am planning on using removable parts that have I/O mounted to them. It will be then replaced by a new fixture with a separate block.
Thank you for your time.
Depending on what type of I/O you are using will depend on what is 'plug and play'.
Typically any I/O modules will be plug and play, as long as you are replacing with the same module.
The ethernet adapter however will not have an IP address when it is shipped, so therefore before adding to the system this IP address will need to be assigned.
This is for Rockwell products but I am sure Siemens and many other brands are the same.
Mark
If I assign the I/O a static IP, will I be able to inhibit the logic when I add a new I/O block? And that way keeping any existing logic specific to each individual fixture? I will be running a compactlogix system.
Yeah you would be able to do that.
All you would have to do is have separate routines for each I/O block and put a condition in front of the JSR.
However you would also need all of the unused I/O blocks in the I/O configuration tree, where you will get yellow exclamation marks and an I/O not responding, which for me when writing code will safely stop the system.
Mark
Hello, I have a ControlLogix L73 at firmware 24.11, Logix Designer at version 24 I have a 1734-AENT Point IO ethernet adapter, the box says...
1,641
Consider two control panels 100 meters apart. Customer is to run fiber between them so the PLC can talk to the HMI. Each panel has an A/B...
29
8,703
Hi guys I hope your all safe and well , I have a question regarding a slc 505 on ethernet is it possible to add a ethernet remote I/O module...
1,879
I am replacing a powerflex 525 on ethernet/ip with a stratix switch. I am upping the drive from a 2 to 3HP. All i should have to change is drive...
1,130
This may be a simple question. I understand the concept and application of analog modules (i.e. Compactlogix) for transducers, and outputs for VFD...
2,102
