Ethernet Step 7 communication problem
harrydeharry
May 2008
Delhi
237
I am trying to access PLC 317 via Ethernet but not success so far... don't know what wrong m doing,
it shows connected but no ping.
please see the attachmentip address.jpg for both side settings.
in PG/PG I select TCP/IP (my Ethernet port is ok)
Thanks in advance.
harry
A very happy new year to all..
Your interface is not networked.
yes the ethernet port is not being used....but it has been provided a IP address and subnet mask....what else I should do to get connected....I need to upload the program via Ethernet...as i never did it so need to learn it also...will it not work un till not networked?...
Need a communication ethernet block for Step 7 (WinAC & LC)with a Bosch (torque runner) LT303/4/5. Right now is a pain going through VB...
2,550
Morning all I have a profinet network with a combination of S7-315s and an S7-200. One of the 315s has been coded in TIA portal, the others in...
3,261
Hello all, I am hopeing someone on here can help me. We currently have our plcs connected to an ethernet network, connected to this is a desktop...
4,289
Hello, We have been using Ethernet for our plcs for quite some time now. The set up of the interface in Simatic Manager, is set up in PG/PC...
9,711
Can you use an existing OPC over Industrial Ethernet connection to update code on a S7-300 PLC using Siemens Step 7? I found something somewhere...
3,121
