Hello,
We have been using Ethernet for our plcs for quite some time now. The set up of the interface in Simatic Manager, is set up in PG/PC interface.
However, several times I have noticed that I can find the Ethernet devices in the "accessible nodes" window. Devices such as panels, CP cards, CPUs etc. But when I try to monitor blocks or hardware configurations, then I can not get connected. So, several times I would have to change the PG/PC interface from ISO ind. Ethernet, to TCP/IP... It seems like it depends what I am connected to. If it is through a CPU, through a switch or a CP card.
If I can't get connected then I change the PG/PC interface in either directions, and it will work.
Point is that I would like to know what the difference is between ISO and TCP/IP set up in the PG/PC interface. I know it has something to do with IP versus MAC addresses, but I would like to understand it better... Does the program editor use it differently than accessible nodes?
Anyone?
Brg
Andreas
Anyone?
Brg
Andreas
