Ethernet Temperature Probe
swapped
Mar 2010
nowhere
28
Hi All!
I'm looking for an Ethernet temperature probe that I could poll from a logix plc to get temp readings. I have not been able to find anything like this so far. Can anyone suggest something they may have used in the past. I basically want to put these in panels and IDFs to keep an eye on temperatures in case an AC unit fails.
Thanks!
I've seen temperature sensors with some ethernet protocol advertised in IT venues. Something like SNTP(?)
Try googling for terms like server farm, cooling, temperature, alarm.
You could maybe use one of these and then wire a T/C to it.
It might be simpler and a lot less expensive to just monitor the cabinet cooler for a fault or use a temperature switch.
Google SNMP temperature monitor
I use switches in most cabinets but would like to put something Ethernet based in IDFs and panels that have no IO.
Not sure how I would go about polling a SNMP device from logix?
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
226
We are planning a new installation. Large industrial building. PLC will be in one end climate controlled room. Some distributed Ethernet/IP I/O...
1,959
Greetings, I've done some basic web searching and haven't been able to find what I'm looking for. I'm looking for a basic Temperature/Humidity...
10,176
I had a nice Omron temperature controller spec'd out that utilized a comm module on DeviceNet that I could tie multiple temp controllers on to it...
5,989
142
