Multiple Channel Ethernet Temperature Controller
boiler-todd
Nov 2003
Layton, UT
47
I had a nice Omron temperature controller spec'd out that utilized a comm module on DeviceNet that I could tie multiple temp controllers on to it. The specs have now changed to use Ethernet/IP instead. I have 10 heaters to control or 5 pairs of top and bottom. I have found some dual channel units that are ethernet ready. But each one requires an IP address. That will use up 5 addresses and with four machines that is 20 addresses. I have two questions.
  1. Can I use something like a subnet to minimize the IP addresses. The four machines are identical and I would like to just dump one set of addresses instead of adjusting each machine to its own allocated addresses.
  2. Is there anything out there that is a multiple channel temp controller for like 12 channels and ethernet.
Thanks for reading...
Todd.
I used a Honeywell's HC-900 for 16 temperature loops. About the same size/format as A-B SLC.
Convenient because operator interface doesn't need special software, loop screens and alarm screens are preprogrammed.
I/O is modular. AI's are universal - take either RTD or any of the Thermocouples. Includes an autotune algorithm.
http://content.honeywell.com/imc/pi/hybrid/
So here is my situation, I have multiple channels that can be individually programmed to be on at different times for various amounts of time. I...
1,261
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
492
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
317
I'm trying to use DTM browser to make make modbus poll from RTAC. I'm able to get the points in first poll object. But not able to get anything in...
125
