Euchner gate safety module (OSSD issue)
Krone
Oct 2020
Denmark
Hi PLC talk
I have a problem with a Euchner MGB safety gate.
I'm working in studio 5000 and my CPU is a 5069-L320ERMS3. The input I'm using is 5069-IB8S
I'm using the RIN (Redundant input) for my safety chain.
The problem is that it output from the device is OSSD, which I don't believe that the RIN allows (unless I use the test output pulse from the input card, but that is not possible here). One or two secounds after I reset, the RIN goes from OK to CI state (Cycle Inputs).
Is there a work around this or another safety element that I can use, that allow the OSSD?
BR
Anders
Hi PLC talk
BR
Anders
Use the Light Curtain instruction, it has a digital filter which takes care of OSSD inputs.
So I am looking at installing an external rfid key reader with four out puts that will go to my plc(AB)(in puts) and want to use them as user...
1,540
We are special machine builders and have a customer who wants to implement the Euchner Electronic Key System (EKS). We haven't had much luck in...
1,735
I have a SLC 5/04 that has to communicate with a Euchner EKS (Electronic Key System)thru the AB serial port. The Euchner serial protocol is 3964R...
3,252
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
Hello, I have problem i'm working on boiler plc, but i get to the problem that i can't solve myself. I have problem with material gate. I need to...
358
