Events in RSView32
Jan 2003
Michigan
490
Im trying to trigger an event on a true to false transition. I know the event list triggers on a false-true transtition of the expression. Well, ive put NOT TAGNAME in the expression, hoping it will trigger on a true to false transition. However, it appears that this is not the case. This is for a door with an open and close limit switch. There are events that causes the DoorPostion tag to become 0 on a close limit and 100 (fully open) on the open limit. Oh yea, this is for animation of the door. Anyways, I want to trigger an event (which runs some VBA) on a ON FALSE for both switches (to show it going up or down).
In wonderware we had the ability to attach scripts to any tag with based on On False, On true, While false, and While true. I sure miss them here....
Thanks in advance
And then use the derived tag to tigger the event? That sure seems like a round about way of doing it. Is there not a way to make an expression that will cause the event to trigger on a ON FALSE?
Well, it does work. I needed to stop the event model before changes would take place. I thought the simple NOT TagName should have worked. Never mind. Thanks anyways.
hi, i am trying for create a event but its not working. How can i print a trend graphic every 30 minutes? can you help me?
1,862
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
94
I'm using a Micro850 with a Panelview 800, programming in CCW. We'd like the customer to be able to schedule the system to startup at a certain...
150
Hi guys, I've got problem about my Alarms services (i think), that happen after installed Visual Studio. I did a few things like, Repair : Studio...
156
Hello, Does anyone have experience managing the FactoryTalk alarm & events SQL database from outside of FactoryTalk? Essentially I'd have tag...
1,306
