EWeb Module - Need Help
SortedLogic
Aug 2008
Texas
I have an Eweb Module in a Contrologix 5000 Chassis with a DH-485 Com. Module (No Processor), Can a Eweb Module access Input / Outputs from a SLC 503 on a Data Highway. (O:3/1)etc.
Yes but as far as I can tell nothing in that senerio will work for that besides the contrologix rack and the SLC 5/03
Can you define "access"?
Are you trying to display SLC I/O points on webpage hosted by EWEB?
This is not possible, EWEB module can access only Logix based data.
If you just want to have a PC running RSlinx, then you Yes, you can bridge via EWEB and DH-485
You need to define your application
Environment: ControlLogix 1756-L61 with an EWeb card. Trying to send a byte to a remote host via TCP. Creating socket - success. supply...
2,291
All I'm trying to get a 1756-EWEB module to connect to a webservice to get data from a database. I'm not stuck at the connection phase, have that...
1,886
I just installed a 1756 eweb module into a 10 slot chassis using contrologix with an 1756-L71 processor. The module has a 10.5.48.xxx IP Address...
3,273
Hello everyone, first post here. I don't know if what I'm trying to do is possible, that's why I'm asking here. I have some tags that I need to...
5,587
Hi I must write a custom webpage, from wich a user can save a csv file that contains the controller tags and their values. I use a 1768-eweb...
2,670
