Excel and rsview32 help
stu
Aug 2005
England
785
Hi Guys
i have a question for you, i have a project in rsview32 which production would like to have a downtime sheet pop up which the operator will fill it out, i am hoping to use excel speedsheet.
is this possible?
You want the spreadsheet that pops up to be in excel, or do you want to write to an excel file?
Stu,
From RSView, there are commands that will start any external program. You could use a RSView tag to run a command to start your Excel spreadsheet. Of course this will not verify that someone actually filled it out.
Once I had to do a sheet to record values from RSView. I did not use Excel, but I set up memory locations in the PLC, and mapped those to blank lines on an RSView menu "sheet" that popped up on the screen. The sheet had instructions, filled-in boxes, and empty boxes to be filled by operators. This sheet had to be done weekly, printed, and sent to a state department. So my PLC only had to have memory spaces for 1 weeks data, then it was cleared and the memory registered recycled for the next week.
Good friends, I'm new to the forum, I'm working with RSview32, someone can help me how to make a macro in VBA, to save some data in Excel. to...
1,967
Hi, I have 2 problems. 1- I have an RSView32 application which contains a memory tag defined with these parameters: Min: 0 Max...
9,009
Hi guys, It is possible to execute the Excel.exe when I click the button at RSView32? Is there anywhere we can do this without doing any VB...
6,316
Hi, I would like to create a vba code to format the dbf files that RSView32 creates to make readable reports. For example, if I datalog a tag, I...
17
12,527
I am trying to get an excel spreadsheet to reflect a value that is input into rsview32. I have set up a DDE Topic. My problem is when I type...
6,746
