Excel Crashes on starting DDE Links
OutaControl
Jul 2015
Ohio
I have a spreadsheet I use to pull data from a RSLogix PLC using RSLinx. It runs fine on my old XP computer but crashes instantly on my Win 7 computer. Both are running Office 2010. I don't think it is related to the Google Chrome issue as it is installed on both. I tried uninstalling but it made no difference. I am using RSLinx Classic running as an application. I have also tried using the WonderWare DASABCIP server instead of RSLinx with the same results. Any help is appreciated.
Other Apps
I had the same problem. I found out that another software on the computer was using DDE and that was causing excel to crash. The software for me was Logitech Setpoint (Wireless Mouse).
Hope this helps.
Hope this helps.
You sir are a genius, that was exactly the problem. How did you determine what other programs were using DDE?
Thanks!
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
93
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
755
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
574
Hello, I want to send the data from Rslogix500 to Excel. I created a connection between RSlinx and Excel. The values in Excel automatically...
1,205
Hi guys, Im back again, this time I cannot minimized excel even though i put 6 on the exec mode.. this is my cicode.. Exec("C:\Program...
1,097
