Excel data find from Row and Column value
nikhilec2007
Dec 2014
Gujarat
36
Hi all,
I am trying to read data from excel cells matching with corresponding header column and raw value.
For example, refer attached image.
From one of my Numeric Input, should find the corresponding value from first column. e.g if my numeric input value is 00001, it corresponds to raw 2.
Now depending second input value, say current date, it will find corresponding value from 2nd raw (which is from 1st numeric input)
e.g. if my 2nd input value is 1/1/2015 (may be today's date), then i want final value to be find from excel is "Goto1"
If anyone having previous experience with this kind of example, please suggest.
I hope my question is clear... If doubt, please ask, I will elaborate more.
not all clear
Do you wan't to filter information in excel?
or do you wan't to read specific information from excel from another program?
because if the last is the case, you can maybe use visual basic, you can read/write information easily, and communicate with other programs/ resources
kind regards
Excel data read from FTView SE
I apologize for forgetting to mention that I need to read Excel data from FTView SE SCADA.
I guess VB would be the only solution.
But I am no good at VB, so if someone can guide for startup, I will try to complete rest of thing...
kind regards
Hello, I want to send the data from Rslogix500 to Excel. I created a connection between RSlinx and Excel. The values in Excel automatically...
1,202
Hi everyone! I want to use a Siemens LOGO! to a level monitoring system, but I want to send that registered information to a monitor, (i think i...
457
Long time member, first time poster. Last night our plants wireless network died, shutting the whole plant down. As a result, I have been tasked...
1,553
Hi everybody, I was given a large excel file with 1,000 rows and 7 columns that are arranged in a way to show the total volume of a cylinder at...
2,663
Hello Everyone, I am uploading a CSV from a Click PLC, doing so the rows are in groups of 10 cells (columns B-K), below that in the next row is...
2,922
