(8{)} ( .)
I've been in this business that I rarely get excited about something new but I just finished a project in 1 hour.
The project was as follows. An existing SLC-5/05 was controlling 13 VSDs with Analog outputs. The customer redid all of the panels and somewhere along the long more than 25% of analog outputs got fried. No analog output module was available in time so I used a WAGO 750-880 using CoDeSys 2.3.9.44 (brand new) with WAGO's Modbus network configurator to connect the 13 drives (all had Modbus TCP) to one of the WAGO ports. I had the SLC-5/05 read and write EIP to the WAGO. The actual drive commissioning took about 10 minutes(!). It was the data mapping to/from the SLC and setting up the VSD's that took the other 50.
Kudos to WAGO on this one...
OK. I'll leave you alone now...
