Exor Uniop Upload Problem
isteak007
May 2009
NewYork
216
Hello,
I want to upload a project from Uniop etop312. But when uploading it shows an error (CAN'T LOAD PLC DRIVER) and want a file D32UPLC22.DLL. But i have the file on Software folder but it is not working.
PLC:Siemens S7-200
Can anyone please tell me what is the problem?
ISteak
Uploading from an Exor panel is an emergency option for the case you have no master program anymore.
Check which firmware version is running on your panel, and check for an update.
Uniop Running 5.50 firmware verssion. I update my software.
I don't have the master program.
But i need to upload it.
any idea about "Can't Load The PLC Driver"
As we're using Etop20 and 50C screens I'm not complete familiar with the 312, but can't you ignore this message?
I suppose that you're using Designer,or are uploading on another way?
What is the version of your Designer?
I've seen that the most current firmware version for your screen is 5.90 (G).
Thanks for your reply. No the message can't be ignored i tried several times.
I am using Designer 6.
I didn't update the firmware because it might cause any problem in Uniop Screen Data.
I upload the ROM file but i can't open it. It is also showing driver error.
I insatall Designer 6 in several Laptop and PC tried again and again but same problem
Well you can try to upload with Designer 6.10 which is free to download if there is already an installed Designer version on your PC / Laptop.
If you do an upload you probably get a program where a lot of buttons and text are re-placed / in a different font type.
Are there error messages in the screens of your panel?
What is your communication method?
I tried with Designer 6.10 and Designer 5 both same error.
i do a rom file upload but it's just a file uploaded from (Uniop Data Exchanger Software)
but i cant open this file using Designer software it shows Driver Error.
and i also tried direct upload from designer 6 software it is showing Can't find the PLC Driver.
i am communicating with the panel by ethernet cable
I attached my uploaded rom file from UniData Exchanger.
Please check it and tell me How to open it?
When i try to open it is showing error "Can't Load PLC Driver"
ETOP Model: 312
PLC is S7-200
please check the images too
Dear Sir,
We have an installed EXOR HMI (UNIOP etop20b) on a machine, we want to upload or make the backup of user program but we don't have the software. Please guide us to make the backup of user program or provide the link for Designer 6.0 software.
An early reply will be appreciated,
Thanks and Regards,
Muhammad Waseem,
Automation Engineer.
UniOp Designer Software
Dear Sir,
Thanks and Regards,
Muhammad Waseem,
Hi Guys, I'm in the process of collecting all the Programs etc from an integrator to use for a HMI Upgrade on a newly installed machine. The...
6,332
Dear Folk, Does somebody know that who is the vendor for Exor - Uniop product.. especially in South-East Asia. Regard
2,895
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
125
Maybe I am a bit thick, but I spent ages trying to get the Combo Box in Exor JMobile to work, turns out that there is a trick that doesn't seem to...
631
