kamenges
Originally posted by realolman:
so in "normal" VFD / motor operation, is the volts/ hz ratio maintained by the VFD as we mindlessly crank the frequency up and down to vary the speed of the motor?
Yes...more or less. This is more true in volts/hertz mode than in the other modes but it is largely correct. FVC and DTC will modify this some to maintain the correct motor flux and torque levels but on the whole this is correct. Motor speed is based on applied frequency. In order to maintain the correct motor flux the applied voltage needs to increase at the same ratio as the applied frequency. Those darn drives are doing all sorts of stuff under the hood.
what I'm wondering is why do this rather than size motors and gearboxes "Normally"?
Size, cost and performance. I am basically getting twice the horsepower capacity out of a given size motor. Granted, you need the larger drive to take advantage of this. But in some applications size matters. And as others have said, assuming the rest of the powertrain can handle it, this method can get you out of a sizing snafu reasonably painlessly with very little downside.
Keith
