Exponential functions
Sep 2016
norway
Hi all, this is my first post here and i hope you can help.
I am using a Omron CJ2M CPU31 and i am struggeling with an error in structured text when am working with exponents.
I can do 100,0**2
But not:
test1 =: 100,0;
test2 =: test1**2,0;
This leads to an compile error: KBASE 'constant out of range' error.
Any sugestions on how to avoid this issue?
Hey,
Thank you for the reply. I figured out how to do it, but its still a little weird to me that the compiler did not accept it as it was.
I had to store mye "power" in a variable as well
test1 =: 100,0;
test2 =: 2,0;
test3 =: test1**test2;
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
16
397
Given y = 2^x . Find x when y is known. IF x is not a whole number, reject it ( move -1 to result). 1. Given CPT, XPY, LOG available 2. Can...
16
5,038
Recently I posted about a process that was poorly designed with the PV being upstream from the control, but there is a new hurdle in this process...
17
5,427
is it possible to change the display of real numbers in codesys 3.5 while online from exponential to decimal values?
2,003
Can anyone explain why the following expression, used in a CPT block, does not work in RSLogix 5000? I am storing the result in a DINT tag...
2,556
