Export from RSLogix5 to AB 6200 Software
JamesWSY
Jul 2005
Jakarta
81
Hi..
I have difficulties on export the project from RSLOgix5 to 6200 series software. I try to import from 6200 series and I found the CTRee error. How to make succesful import?
Thank you
James
This goes back a ways. 6200 is DOS based and created a lot of files. If you are looking at only the ladder logic, I think you should be able to upload from the processor with either package. If you are hoping to bring in the descriptions. There is not much you can do here. 6200 was weak in the descriptions and realy required an addition program called Taylor Document. If you could find someone that still has a copy ICOM, the beginning of RSLogix, it may allow you to do this in 3 steps. 6200 to ICOM then ICOM to RSLogix. IF not, looks like a lot of keyboard time. I am sorry I could not be of any real help, and alot of this is from memory but has been 12 to 14 years sense I used this.
To export from 6200 to Rslogix5:
I believe that RSLogix5 can open 6200 files natively.
To import into 6200 from RSLogix5:
I believe that you have to save in RSLogix5 as ".X5" files, then in 6200 you can import both code and comments from one of the menus (dont remember exactly which). Possibly it is called "AI" format in 6200.
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
112
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
134
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
85
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
135
Good morning, I have a Emerson/GE PLC with Cimplicity SCADA. I need to export data of a specific point/object to a CSV file and load the CSV file...
290
